I have started receiving a fail on startup. The transponder is sending and receiving with ATC and is accurate. When i contacted Apollo they informed me the unit is no longer supported and they don't have the error I am getting. He is going to look into it but also said they wouldn't give out certain information as it might be propitiatory.
OK, i get that but I still would like to know what's failing. When i start the unit and get the fail I turn the small knob to cycle through the tests, Voltages , transmit and receive are all OK. The fail is the "DSLT".
Anyone able to tell me what the code indicates?
Thanks in advance
Thanks in advance
