any experience with clear-nav GPS antenna
rv10soon
Active Member
I bought a Garmin GNS 430W w/o an antenna? Does anyone have experience with the new "stick on" clear-Nav GPS antenna. It claims to offer the same 27dB gain as the Garmin GA 35 waas antenna.
No experience, but two comments:
1. ACS says it works with a 430; but 430W uses a different antenna than the non-W.
2. It is probably technically illegal to use your 430W for ifr with this antenna, since it is not installed per the installation manual.
