My AntiRotate toggles use a washer with two rectangular tabs. One internal tab fits in a slot in the switch body, the other is external and fits into a slot cut in the panel. The result is a switch that will not rotate when attached to the panel. Desirable to me.
How does one cut the small rectangular hole in the panel for the anti-rotate tab to fit into? Just drilling a hole for the tab to fit into comes to mind, but if there is a reasonable way to make the hole the shape of the tab, that would be preferable. Square drill?![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
