Antennas
Can you hear me, now?
Steve,
I mounted a single exterior steel comm antenna on the Bandit under the belly aft of the rear seat. I heated it and bent it even more so it cleared the ground. All other antennas were internal. I mounted the GPS on top of the fuselage under the rear part of the canopy, worked well. I mounted the transponder in the left wingtip. My Rocket is set up exactly the same except all my GPS antennas (3)Old Apollo & Garmin 396+Nexrad are under the cowl mounted to the firewall. On another subject, I used LED wingtip/strobe lights and really like them. Cheers...
Smokey
