After spending a number of hours scouring the archives and builders sites, I thought I had the placement for comm antennas figured out.
Dual bent whips on the belly, outside bay for separation and under the seat pan.
Since on the 6A the autopilot roll servo is in the same bay, I decided to move the center of the Commant 122 back a bit further. My seat pan is removable so I could get to it if I had to.
I didn't have the flaps mounted when I made the final decision and after the holes in the fuselage were all drilled and the doubler made, I got worried about the proximity of the end of the antenna to the flap.
Sure enough, the tip of the bent whip is about 3" from the edge of the flap when it is lowered.
The pictures are not great but I think they get the point across. I know I won't spend much time flying around with 40 degrees of flap but is the antenna to close? I hate to drill another complete set of holes.
Dave A.
6A build
![antennaflap.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Fantennaflap.jpg&hash=c149a7d167ab048a5d486873ba50b5d0)
![antennaflap2.jpg](/proxy.php?image=http%3A%2F%2Fpages.suddenlink.net%2Ftismuoi9%2Fantennaflap2.jpg&hash=543641e4dd277e452cc4794b0a3efc8a)
Dave A.
6A build
