I am just finish up my G3X touch installation on my RV8. I mounted the Remote GX23 transponder in the rear where the rear mounted battery would have been ( mine is on the firewall). All seemed good and I was checking the manual to make sure my distance between the antennas was enough. Gamin says 3 feet. Then i noticed that Garmin says the Transponder antenna needs to be 3 feet form the actual GX23 unit.
I have seen the GX 23 mounted in the rear where I have it. Any one who has done this , where did you mount your antennas.
I am hoping this 3 feet from the is like the requirement that the magnetometer must be mounted 10 feet from any steel. Which is just about impossible on any RV.
I can switch the ADSB with the transponder , but would't the RF interference still be a problem ?
I contacted the G3xpert, but last time it took a week to get a response.
Any comments or help is appreciated.
