Com antennae: I see that some builders have their com antennae under the rear seat floors. I was wondering if one could not install your two com antennas under the baggage floor just behind the steps. If one then make inspection panels in the baggage floor in the same area, you will have access to the step bolts as well as the two antennae in future?
Transponder and marker beacon antennae: I thought I will fit this under the two front seats?
VOR antenna: I would like to fit it in the last "bay" of the tailcone. Have done this in a 7 and worked well.
Any ideas will be appreciated.
