OK, so I am convinced. I have a set of Zulu 2's sitting in my online shopping cart- ready to buy- as we speak.
Question of the day: you guys (and gals) like the straight cord or the coiled cord?
Thanks!
I personally prefer the Zulus (and have 2) but want to provide a little insight I picked up when shopping for my wife's headset. Turns out that there's a slight difference in how the brands fit around the jaw area. For my wife, the Bose (X) fit better back there which means that there wasn't an air gap and therefore the ANR was much better.
I like them both and could probably go with either. She prefers the Bose without question. Now, all that said, Lightspeed will give you (at least at OSH) Zulu 2 ear cushions that go on the original Zulus and are supposed to have a better fit for more people. My wife has no interest in trying it because she's happy as is. I also don't have first hand experience with the newer Bose.
Bottom line: try each personally in a flight environment and see which you like.
Bob
I have an old DC headset with Headsets Inc. conversion in the back of my RV-4, I have tried it back to back with the Zulu and it’s the same, very good value if you have a decent old headset to convert, not a big fan of the 9v battery they use to power it but it’s ok.FYI, for anyone else who comes along later looking for info... I've flown in RV's with both the Bose X and the Zulu, and can tell no difference between them. And i've done side-by-side comparisons of the Headsets Inc. upgrade to the Zulu, (Headsets Inc. in both a David Clark and an Alpha Helmet) and the Headsets Inc. performs at least as well as the Zulu (didn't have the Bose to try at the same time).
Also, according to other reviews/threads/etc. that i've read, the Zulu and Zulu2 don't seem to fit women that well, but Lightspeed offers a different pad for the over-the-head strap that apparently fixes the problem. Apparently women find the Sierra more comfortable, but I don't know anything about its noise performance.
I used Headsets Inc. amp cable and auto shutoff box so it ends up being the exact same thing you?re suggesting, it works great, just the 9v battery doesn?t last as long as I would like. Ships power is the way to go!Russ, I have two suggestions for you (and for anyone installing Headsets Inc. systems). One, is the Rugged Radios replacement cable. This cable integrates a 9V battery box into a stereo cable and works beautifully with the Headsets Inc setup. As a bonus, it automatically turns on/off when it detects your COM is on. I used this cable when I installed the HI kit in my Alpha helmet.
Two, is my next plan... I'm ditching battery boxes and going LEMO. There's no reason to use a battery for anything in the aircraft when you have ship's power there anyway. My Alpha will be getting a 12V-9V converter put into the cable along with a LEMO plug, and my Lightspeed will be getting the LEMO cable as well. No more batteries!![]()
Another vote for Zulus here... and straight cords.
Oh, sorry, I wasn't very clear... My intent is to put the 12V-9V converter in the headset cord for the Headsets inc. units. That way the LEMO jacks work as expected by anyone else looking at them... Ship's power at 12V nominal. I suppose I could put a 12V regulator there to lock it at 12V, not sure how critical that is.You may want to use 10V regulated power rather than 9V. The Bose data sheet indicates that a minimum 10V is required, the Lightspeed may be similar. By putting the regulator well upstream of the LEMO jack. The current limiting regulator will then provide protection from any short circuits in your jack power wiring. The 10V is also compatible with the Headsets, Inc. requirements.
Russ, the main benefit to the rugged radios cable is that you don't have to cable-tie a second cable to your stock headset cable... The finish is cleaner. I agree the functionality is the same, and if you've already got it built there's no reason to change it.
