Hi all,
I've searched here and found some answers, but I still have some decision to make about the placement of the transponder antenna in my RV-7A.
It's a Garmin GTX-330 and I intend to use RG-400 coax.
The installation manual (revision J, march 2005) states:
There is no indication given as to where to measure the distance between antenna and GTX-330, so I assume the measurement has to be taken from the antenna to the nearest point on the box (rear corner if antenna near firewall or faceplate corner if antenna is under the seats or baggage compartment).
So my options are :
The position under the seats might also prove problematic due to the gear legs.
What is you opinion?
Best regards
- To prevent RF interference, the antenna must be physically mounted a minimum distance of three feet from the GTX 330.
- for RG-400, maximum cable length : 6' 1.3" (was 8'8" in earlier editions of install manual)
- make the coax cable as short as practical.
So my options are :
- Antenna near the firewall and the fuel venting point, distance to GTX-330 is 33" (Garmin wants 36"), coax length is 4 feet.
- Antenna under right seat in front of rear spar, outer bay. Distance to GTX 330 is 36" and coax length : 8'8"to 9'
- Antenna under left seat, middle between front and rear spar, outer bay : Distance to GTX-330 36" and coax length: 8'8"
Best regards
