After exchanging a couple emails with Dr. Dave I made this trailer concept #3:
I posted multiple images and an animation here:
http://www.box.net/shared/8s6psmv2l1
Notes:
Notes:
- I saved the animation in Windows Media (WMV) and Quicktime. The WMV is a little higher quality, if you can play it.
- The goal was to minimize size, weight an wind resistance. This one is not the "super hangar on wheels".
- I'll add the trailer tongue & axle
- The wings will obviously need to be supported with some type of padded rack
- I don't know if we can squeeze the RV-12 gear between the trailer tires. They measure 84" outside, and the trailer cannot be wider than 102" in most states. That's only 9" per side for the trailer wall, wheel & fender. The alternative would be to put the deck above the wheels, making the trailer much taller.
- Those small doors near the wheels are for easy access for tie-downs.
