JohnR said:
This week was really busy work wise and I am just getting to the rudder trailing edge. I was going to use the proseal I got from Van's to glue the edge tonight. When I got it our it is only 1 oz. I don't think there is enough of it to do the edge. How much proseal or epoxy did it take when you all did yours?
I dug around and found a 1 oz container of 30 minute epoxy also. Maybe I could use both but would prefer one or the other. Doesn't look like I have enough of either though. I was really hoping to get this done tonight. Thought about just riveting it as some have done but I'm not sure I want to try that.
Comments appreciated.
I used the 1 oz. thingy of proseal to do my rudder. 1oz is not only enough to do your rudder, you'll have enough left over to:
1) ruin your pants
2) glue the trailing edge down to the aluminum angle (smear some boelube on the angle first...makes life much easier a couple of days from now....put boelube on the clecoes too)
3) track the black goop on the bottom of your shoes into EVERY room of the house
etc etc etc.....
After all that, you'll still have enough left over to help 3 of your friends glue their trailing edges and ruin their pants
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Once you start working with it, you'll see that Vans ain't joking when he says all you want is a THIN coat. Anything more will either have to be squeezed out (not as easy as it sounds) or will leave a bump. I found, after much experimentation (here defined as "making a mess" ) that putting a tiny little glop on the AEX wedge, and then using the side of a popsicle stick to smear it out really really thin worked pretty well.
There's just no way to do this without making a mess. Just dive in, have lots of gloves handy, make whatever mess you have to make, and then clean up with MEK (stuff comes right off, believe it or not).
edit: I'll just add one thing about using epoxy. Most "30" minute epoxies that I know of are really more like 10 minutes usuable, and 30 minutes until it turns into a 150 degree Farenheit hunk of plastic shaped suspiciously like whatever container you happen to be mixing it in. West Systems is really stable and reliable. The junk you get at Home Depot is hit or miss.
