grjtucson
I posted my panel design a couple of days ago in the Dynon/GRT comparison thread and based on feedback have since made some changes. It is pretty close to "there" but I wanted to ask again for final critique before I start carving metal. I'm hoping there's some folks that weren't following that other thread that might weigh in here.
My mission is IFR "light". I'm in Southern AZ so the only IFR I'm likely to fly here is training, IMC in AZ pretty much means stay on the ground. However I will fly to California regularly and the marine layer there is my issue. I don't intend to plan for enroute IFR or approaches to minimums (or even near minimums).
I am certain I'll fly more hours getting the rating and keeping current than I will actually using it, but I'm OK with that as I believe it will make me a better pilot and I want the flexibility to plan for flights that might require penetrating a layer.
I want my panel to include:
- dual axis autopilot
- dual screen efis/ems (solo from right or left)
- IFR GPS
- single panel comm
- single panel nav (vor/loc/gs)
- TIS traffic
- handheld backup GPS + XM weather (tied into panel)
- handheld backup comm (tied into panel)
Here is my latest plan, click for larger image:
![](/proxy.php?image=http%3A%2F%2Fgeorgejenson.com%2F16+Nov+08+Panel+800px.jpg&hash=df7cf54ad56ada4e2bc5b2ebbd8f99ec)
Notes:
- this is Van's stock panel, I'm planning on having it water-cut
- those are GRT Sports and will have the ARINC option
- that's a Garmin 430W + Garmin 330 Xpdr + TruTrak DII VSGV (pic probably not 100% right)
- GRT EMS (EIS 4000) will be mounted behind panel so only the display and the 3 buttons will show
- that's a Garmin 496 on ball-mount movable to either side and still tied in (pic is a 396)
- setup for solo right or left, I'll solo right mostly
- sticks have PTT only
- Icom A6 + all Headset/Mic Jacks just aft of fuel valve
- LRI is homebrewed and totally electron free
- elevator trim tied into trim monitor, manual aileron trim
- all lighting switches on right side are off to the left, on to the right, top one for panel is actually a dimmer knob
I do have a couple specific questions that some of you might be able to help with:
1. Does the EIS 4000 have an alarm/warning light or should I wire one into the panel?
2. Is the TruTrak "control wheel steering" a function that is not on the AP head already, meaning do I need the separate switch? If so, I'm thinking I should add a panel pushbutton? If it is optional, what are your thoughts on its utility?
Thanks in advance for your comments.
George
- IFR GPS
- single panel comm
- TIS traffic
Notes:
George
