Piper J3
I found the VA-214 oil hose that routes from the oil radiator to the oil pump on the right side of the engine was abrading on the muffler exhaust spring. This is the hose that passes thru the right front cylinder exhaust elbow, curves close to the cowling, and then passes over the muffler to connector to the oil radiator.
In my case I found the fire sleeve worn completely thru to the stainless steel weave that protects the base hose. No telling how long this condition existed or how long before the hose would have been completely compromised. A new hose is on order from Van’s.
It seems the problem is setting the correct angle when tightening 90° elbow on VA-214 hose at the oil radiator fitting. This is a little bit of trial and error because you are working on the radiator when it is suspended in mid-air and not in its final mounting position when fastened to the lower cowling. I would suggest verifying the hose routing once the radiator and lower cowling are mounted in position. With the top cowling still removed, it is easy to feel with fingers to see if the hose is equal distance between the two exhaust pipes on the right side of the engine.
![2igd7yw.png](/proxy.php?image=http%3A%2F%2Fi67.tinypic.com%2F2igd7yw.png&hash=9e4e9a0d35509c4034a91df104716fb3)
