Had a gorgeous day and time to experiment with the GoPro.
Did three full stops around the pattern, changing camera position at each and pieced it all back together.
One lap at ZPH
Of note, I didn't get very much "jello effect" without a neutral density filter, yet another attempt with less light, I got a video that had enough to make it unacceptable. I've done some experimenting with an ND filter and it certainly eliminates it but haven't figured out when to use and when not. It does darken the video considerably. Next weekend, when I have time and a bright sky I'll try the ND filter and expose a white sheet of paper for a white balance sample.
Any other input appreciated. Try not to be too brutal, I'm learning.....
One lap at ZPH
