.......For those of you like me not headed to OSH ...... ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have yet another question about the empennage attach section.
After routing my Trim cables through the HS and in to the Elevators I am attempting to "screw on" my trim cable anchor brackets that are attached to the cover/inspection plate.
Must be the builder here is slightly stupid, but there is physically no way those brackets are going to make it so the anchor is half way engaged on the trim cable threads as the plans call...
I did some Archive searching and all I found was that others with this problem simply drilled out the LP4 pop rivets that are holding the anchor bracket to the cover........Others have used screws?
I am guessing if it was supposed to be this difficult to install Vans would have not had me rivet it all together yet... SO I AM ASSUMING, I perhaps done something wrong.
Has anyone else run in to this? What is the best fix?
thanks again for all your inputs, I am always happy that I am not building some fast glass airplane every time I get on here when my brain stops working and you all do the hard thinking for me.......
Joe Benjamin.
Empennage 99%
Wings 60%
99.99% to go........
Joe Benjamin.
Empennage 99%
Wings 60%
