JoeG
I'm off to Lowes in a few minutes to pick up the material for my 2x8 elevator skin bending brake. I plan to build it and use it today.
I'm trying to figue out if I need any spacing between the two boards when I hinge them together, Or do I just stack the boards and attach the hinges at one side?
I have read that some folks use a 1/8 inch dowel. Others have positioned the trailing edge of the skin against the hinges before the fold. Seems like there must be some space between the hinge edge of the boards to allow this to happen.
I'm sure, that like many parts of this project, this will take less time to actually do than I have put into contemplating doing it. I guess that's what they call the "learning curve". I'm already fretting about the trime tab folds...
Thanks in advance for your comments and pictures.
