N355DW
After reading many of the threads here, I have a another question.
Living in FL I do want to add some corrosion protection to my project. I am experienced with spraying and have a nice HVLP system with breather apparatus. This time of year the humidity is not so bad, but I don't think I'll be able to get everything sprayed before it comes back.
I spray lacquer on musical instruments I build, and blushing is a real problem here in FL, even in a climate controlled room. I don't want to spray a wash primer or epoxy in my climate controlled shop area, so the next best as I see it is the Akzo epoxy primer sprayed outdoors.
My question is, is there a problem with blushing with this product? None of the material I can find suggests that it might be, and all the wash primers do say blushing can be a concern.
Anyone experienced with products that tolerate the humidity, please feel free to chime in!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks,
Damon
thanks,
Damon
