yankee-flyer
I've adjusted the return fuel flow and K values as per the posts here and things seem correct. However, the last two reasonably long (45 min to 1 hour each way) flights have produced strange numbers-- or maybe I just don't know what I've been seeing??
On the outbound leg (east) fuel flow readouts at 5200 rpm, 5500 feet, OAT in low 60's showed 5.2-5.6 gph. After landing and spending some time on the ground (fly-in breakfasts). the return leg at 4500 feet, 5200 rpm, OAT about 70, reads 4.1- 4.2 gph, which is what I thought it should. Dividing fuel burned by hours flown gives me the same 4.1 (or thereabouts) gph, so I don't think it's running rich on the first leg of the day. Choke cables checked OK at 100-hour 20 hours ago.
Any thoughts, guy, or am I simply getting more info from the Dynon than I need (or understand)?
Wayne 120241/143WM
Wayne 120241/143WM
