If you want an exact colour match when anodising, make sure that the aluminium alloy of your parts and the anodisers samples are the same (or very similar). Different Al alloys give different responses to the anodising process. Also find out if the anodiser will be using the sulphuric acid or the chromic acid processes, again, each gives different visual results.
Final films can be darker than expected if the aluminium alloy contains silicon, for example. Copper in the alloy can cause uneven films with the chromic acid process.
Sulphuric acid process tends to give brighter, clear colours which retain the metallic lustre.
Chromic acid process tends to give more pastel like colours.
However, the above are generalisations and the final outcome can depend on the anodiser and his supplier of chemicals and dyes.
As 'hgerhardt' mentioned, the coating produced has quite a high electrical resistance.
Best regards,
Jim
