Howdy to all,
I'm using a Plane Power "30a standby alternator" on my RV10. Vertical Power calls for a 30amp ANL firewall mounted fuse for protecting the B lead. BandC's smallest fuse is a 35A. Have others run into this problem? What are others doing for protection? I suppose an automotive style might work, just not sure if it is the best choice in that atmosphere.
By the way Stein is sure nice to work with... Panel should be completed in a few weeks. Getting much much closer to completion. There is a brighter light now at he end of that tunnel
