I am working to install the Andair valve in my -10 and have a question about direction. The valve is a FS20 Type 3 with 180 between left and right with off in the rear direction.
When the valve is what I think is installed correctly and the left /right plate faces correctly for airplane orientation the input elbow for the right tank is forward and the input elbow for the left tank is towards the left.
I think that is what I see on Mark's (Charlie Waffle's) build log but some of the other look different, more like what I would expect with each side towards the tank. Maybe a difference in valves? I believe Mark and I have the same valve.
Link to Marks Log here: https://myrv10factory.wordpress.com...er-pedals-and-rudder-cables/#jp-carousel-1195
Does that sound correct?
Thanks in advance.
E
Thanks in advance.
E
