HIIFLY
I bought these Gas caps from "[email protected] " he engraved them for me and did a Really Great ! Job . A Super Guy to work with and I highly recomend him to all .
Joe Ross N808H RV-8
![DSCN0937.jpg](/proxy.php?image=http%3A%2F%2Fi1136.photobucket.com%2Falbums%2Fn487%2Fhiifly%2FDSCN0937.jpg&hash=3203303faebe97005e8ce93fa0d126bc)
I bought these Gas caps from "[email protected] " he engraved them for me and did a Really Great ! Job . A Super Guy to work with and I highly recomend him to all .Joe Ross N808H RV-8
Yes it is a retrofit and I did use the tank sealant to Glue the RINGS in .
It was very easy to do .
The Keys work easily when you turn them , not hard to turn or over center snap like the Vans original lift tab type.
I Really like them .![]()
Do the andair flanges go inside the old flange or do the new andair caps use the original riveted in flange to hold them tight?/quote]
Yes and use tank sealant (aka Pro Seal) to hold them in place.
I ask because I think the original fuel caps that vans supplies use a different flange than the deluxe caps that Van offers as an upgrade.
Correct....
Do the andair flanges go inside the old flange or do the new andair caps use the original riveted in flange to hold them tight? I ask because I think the original fuel caps that vans supplies use a different flange than the deluxe caps that Van offers as an upgrade.
The deluxe caps supplied by Van's use their own riveted in flange so can really only be fitted during build.
The Andair caps use a flange that is glued (prosealed) into the original Van's flange. The company that makes the deluxe caps also makes retrofit caps (same design and less expensive than the Andair caps).
Pete
