Andair fuel selector screws
Davea320
Anyone know what this means in the Andair valve instructions? Do I really need Loctite 648 or will blue 242 be adequate? I hate to buy a bottle of 648 for just these little screws. Also what are “stagged” screws.
Dave
Blue
I used blue and have removed them no issues. 648 provides less hold strength. I don't remember what mine specified. it's been a few years.
Screws
Dave
No idea what stagged means but they should be pinned.
There's a little dimple on the frame at the edge of each hole. When you're happy with the orientation and the screws are permenant, they each get a hit with a sharp punch in that hole. A tiny bit of screw edge gets pushed into the hole and keeps the screw from moving.
I'm fairly sure "stagged" is a misprint for "staked", which means using a centre punch and hammer to distort the end of a threaded fastener, preventing its nut from loosening off.
Once the screws are in place and you’re done, take a centre punch , position it just outboard of the screw head onto the surface of the housing and hit the punch. It will deform the house a bit pinching the material next to the screw head securing the screw.
Loctite or staking
Keep in mind the instructions give you an option. How difficult are the screws to remove after staking them?
