dhmoose
I'm going into the shop tomorrow to install my Andair fuel valve extension (the valve has already been installed long ago). The extension has two roll pins that are supposed to permanently attach the extension piece to the valve AND the handle plate. With this in mind, it seems like the only way to remove the tunnel cover would be to remove the Andair handle and fascia plate. Seems like a PITA. What have folks done? My limited search turned up these results:
1) Only install one roll pin in the extension/handle plate and "permanently" keep the extension/ handle/tunnel cover as one unit. When you install the tunnel cover, you line up the extension with the fuel valve and go without a roll pin on the extension/valve. This plan sounds like it could make the placement of the tunnel cover difficult/annoying. Also, I'm not sure I like the idea of not having both roll pins placed although I can't see a way that the extension would come out of the valve or handle in flight.
2) Some folks have sectioned the tunnel cover in front and behind the valve so you don't need to touch the valve when you remove the tunnel cover. Sounds like a reasonable plan.
3) Some folks have created a big hole in the tunnel cover. The cover simple goes over the valve handle/fascia plate.
4) Some folks seem to simply remove the handle and fascia plate prior to removing the tunnel cover.
Any ideas or pros/cons? Thanks!
David
David
