I'm about to order some fuel system parts and need some help. I'v been through the VAF archives and the questions have been discussed before, but specifics are a few years old. I'm hoping to get some updated opinions.
Specifically,
1... I saw that there may have been a fuel flow issue associated with the Andair fuel filter. Is this actually true or was it just a perception based on physical dimensions (if true, is it still true)? e.g., post #5 here: http://www.vansairforce.com/community/showthread.php?t=108379&highlight=andair
2... And this post indicates some potential issues with O-rings. But it's a few years old. Any further issues since then? http://www.vansairforce.com/community/showthread.php?t=71529
3... What are the pros and cons between the stock system and the Andair fuel pump/filter combo? Seems that the Andair pump/filter combo might be easier to get installed, take up less space, and maybe lighter given so much less tubing. Anything else? Any comments on reliability between the stock setup and Andair?
4... The part numbers I'm seeing for the 10 are PX375-TC and FX375-MK. Is this correct?
Thanks all,
Specifically,
Thanks all,
