Did everyone use the andair and filter with the 3/8 ends or did some of you get the 1/2 and then have to us a reducer to go from pump to valve. I have one and it is the 1/2 was wondering if it would be best to return it for the 3/8 so I wouldn't have to reduce it down. Also I see pictures with the filter placed between the pump and the valve. Is this the way everyone did it. One last question if you put the filter on to the pump direct what type of stuff was you using on the threads as a sealent. Thanks
