dbaflyer
I have the empennage components complete and was starting to look at trial fitting the elevators to the HS and the rudder to the VS. The AN3 hardware I have on hand (came with the empennage kit per inventory sheet) shows I have 8 AN3-7A and 2 AN3-10A bolts. One of the AN3-10A bolts is used on the bottom rudder rod end bearing. I can not find anywhere on the plans where the other one is used. Anyone? I also see where 6 of the AN3-7A bolts are used. Two per elevator and 2 on the rudder for the rod end bearing attach points. I can not find anywhere for the other 2. Anyone?
I figure Vans would not have included them if they weren't to be used somewhere. I'm not wanting to have any place on my airplane where hardware should be installed but isn't.
Thanks for the help.
