az_gila
Not approved by Vans, but a minor change that makes fabrication easier.
Replace the 3/16 inch thick aluminum angle bracket that attaches the fuel tank to the fuselage with a 0.050 4130 steel bracket like the later RV-7s.
If you follow the original plans, you must open up the thick angle a few degrees - when I tried hammering into submission it just got damaged rather than bent.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The fuselage attachment with the three AN3 bolts and an internal angle/spacer remains exactly the same.
I noticed from internet picture postings that some builders actually installed the fuselage bracket in reverse so that they would have to lessen the 90 degree angle rather than increase it - a job that can be somewhat done in a vice. In my case the fuel vent outlet location got in the way.
In any case, a much easier solution to creating a 93 to 94 degree bracket.
Don't forget the later revision adding a slot for fuel tank ripping off in an accident. Follow the RV-7 plans and add the slot in the steel bracket and put the nutplate on the fuel tank bracket.
A bonus, you actually save 1/2 oz per side as well as being easier to create the precise angle needed.
![metaltankbracket_zpsb1f33685.jpg](/proxy.php?image=http%3A%2F%2Fi644.photobucket.com%2Falbums%2Fuu166%2Faz_gila%2Fmetaltankbracket_zpsb1f33685.jpg&hash=9da82712ed88d1e79bd2e59713023095)
