Does the ampmeter shunt get mounted on the engine or cabin side of the firewall. Or does it matter.
T togaflyer Well Known Member Dec 13, 2015 #1 Does the ampmeter shunt get mounted on the engine or cabin side of the firewall. Or does it matter.
JohnInReno Well Known Member Dec 13, 2015 #3 Choose your side The electronic guys will always tell you to mount their equipment on the cabin side "just because". I mounted my Hall Effect Sensor on the engine side.
az_gila Well Known Member Dec 13, 2015 #4 JohnInReno said: The electronic guys will always tell you to mount their equipment on the cabin side "just because". I mounted my Hall Effect Sensor on the engine side. Click to expand... Since an ammeter shunt is a passive component and should not be temperature sensitive, mount it in a location that keeps the heavy current wires (the current being measured) as short as possible.
