I only had to shorten the front bow, where the rollers fit, so the frame bow is 3/8" above the roll bar, as per plans.
Two items I would like advice on:
1: The rear bow is 1/16" lower than the rear turtle deck from top of the frame to about half way down to the longeron. At that point it increases to 1/8", is this a problem in this area? This is due to the position that the rear bow is welded to the side bows, can't move it.
2: The side bows are 42.75" wide at the front bow when installed and 42.25" when removed from the airframe, I have to flex them to install the frame on the airframe. I believe this is good as the instructions call for 1/2" narrower when off the airframe to allow for canopy bubble flex when installed.
3: The side bows are 42.25 wide at the rear of the side bows when installed and 41.75 when removed from the airframe. Not sure if this is too much? ie: will installation of the canopy bubble pull the rear out 1/2" ?
Regards Peter
Regards Peter
