dhmoose
Simple but frustrating issue:
I was looking at Step 1 and Fig 2 on page FF2-20 tonight. That page deals with the clamping strip that backs the air seal material of the cowl inlets (lower cowl).
They ask you to make a clamping strip (CB-1002K) out of a 1/2" wide strip of 0.063 Aluminum sheet. 2 strips are provided in the kit. Then, in figure 2, they have you drill the 1/2" wide strip in the center leaving....uuuuuhhhhh....a 1/2" on either side?!?!?!? If you drill the 1/2" strip in the center, you'll have less then a 1/4" on either side of the hole...which also brings the hole way too close to the aft edge of the cowl inlet. Am I making sense?
Basically, I feel like we need a 1" wide clamping strip that can be drilled in the center leaving 1/2" forward and 1/2" aft. What am i missing?
Am I crazy? Here's a link to a picture of the manual (click "sign in as a guest", then ignore my cute helper! )
http://www5.snapfish.com/snapfish/share/p=308171361171775614/l=18230720008/g=36541246/cobrandOid=1000/campaignName=ShareeNewReg_30FreePrints_2010Feb/otsc=SYE/otsi=SANR
D
D
