I had surging issues, and had "heard" that a flex line could be the cause. I removed the line and replaced it with a proper stainless steel line with steel fittings. No change.
Subsequently found out that a properly installed and supported (Adel Clamps) flex line is approved and works well. Steel fittings, of course.
I took off my prop governor and stainless pre bent pipe from the factory IO 320 Lycoming. One hour on unit at lycoming factory. It was removed by a certified tech. The unit is in a box on the shelf.Be glad to sell the both together.
Ron 9a
Hi Gil, you have offered me suggestions in the past and value your thoughts. Got a question, my new io 320 came with a prop governor and stainless tubing. I had that remove because I went with fixed pitch 3 blade. Looking to sell both items but don't know what's the two items are worth. Can you help me. Thanks Gil.
Ron in Oregon 9a
