I bought this ALTRAK Altitude hold system from another member some time ago and am installing it in my RV-9A build.
During installation, I was not aware that the 470 Ohm resistor in the LED Engage wiring, was not in the wiring that was sent. As a result, when I powered up the system the first time, the LED blew out in quite dramatic fashion.
I was able to find a replacement LED and then wired in the 470 Ohm resistor.
In subsequent testing of the system now, the "ALT" button light stays on all the time.. I believe I may have damaged the light logic function in the controller. The unit does change on-off state when the button is pressed.
I have tested the altitude hold function by "tilting" the controller fore and aft, and the servo does move the elevator. It's pretty rough/raspy motion but I was advised that since it's a step function control, that's probably how the system operates. Maybe someone can comment.
I was wondering is anyone may have an ALTRAK controller unit (only, my servo is fine) that they'd be willing to sell. I'm pretty sure that the push button light shouldn't be on all the time, only when the system is engaged.
I've asked a VAF Forum Honeywell Engineer if he could supply any schematics or advice on how the repair the controller, but he wasn't sure what info he could locate and/or share. So not sure if it's repairable.
Any advice or guidance would be appreciated!
Tnx,
Andy C.
Tnx,
Andy C.
![IMG_0486.jpeg](/proxy.php?image=https%3A%2F%2Fhosting.photobucket.com%2Fimages%2Fp424%2Facotykcotyk%2FIMG_0486.jpeg&hash=20c2f5369b8bf40fbb9f119f54e21d14)
