bret
So there I was 30 miles to go navigating through the rain and wind trying to get home, then a battery warning light comes on, O **** I knew instantly I had to take action and start load shedding electricity to keep the computer alive to fire the sparkplugs to keep the engine running, as the battery is on a limited life and draining quick, if the battery dies, the engine dies! I needed to decide what goes off NOW, all lights off, It was getting dark and could barley see, all fans and heat OFF, windscreen started fogging up and it was getting cold, then the engine rpm started fluctuating unexpectedly, WHAT THE!, more warning lights started coming on the panel and then the most scary, the engine started to miss and started shaking bad, then no power, them more power and stumbling, very worried I was not going to make it home, it then started slowing down and I got real scared! then I touched on the brakes and those lights brought the computer operational voltage below operational threshold and the engine Died! I used the very last amount of velocity to make the final turn.............into the driveway. WHEW! yes this was in my car tonight, but it was good practice for my all electric Fuel and IGN powered RV! my goodness I hope I never have to experience this in the air.
