Thanks, guys... this of course begs the question of whether I've erroneously adjusted my altimeter. I'm sure it's within spec, but I have it "adjusted" 60' right now, which is a lot on an ILS with 200' minumums.
-Rob
I don't really follow what you mean by the above "adjusted" 60'.
As Jim stated above what do you read on the ground when adjusted to local baro?
IFR Tolerances are shown below which can be found in CFR 43 Appendix E (copied below)
Altitude ------------------- Tolerance +/- Ft
¥1,000 ............................................ 20
0 ................................................... 20
500 ................................................ 20
1,000 ............................................. 20
1,500 ............................................. 25
2,000 ............................................. 30
3,000 ............................................. 30
4,000 ............................................. 35
6,000 ............................................. 40
8,000 ............................................. 60
10,000 ........................................... 80
12,000 ........................................... 90
14,000 ........................................... 100
16,000 ........................................... 110
18,000 ........................................... 120
20,000 ........................................... 130
22,000 ........................................... 140
25,000 ........................................... 155
30,000 ........................................... 180
35,000 ........................................... 205
40,000 ........................................... 230
45,000 ........................................... 255
50,000 ........................................... 280
