alternator
steve vanbatavia
I'm New Here
does anyone know if you need a crowbar or thyristor to hook inline with a low voltage light in your panel if it is ground based and if you are using the nippon 60 amp that is internally regulated with a lamp exitor and dummy spade
Here are some pics I made, hope it helps
Don't know what you are talking about but this should help.
I can't answer because I am not sure what you are asking but the warning light does not need a crow bar or thyristor. If it is a LED you need a voltage drop resistor.
DO NOT USE THE DUMMY SPAD (terminal).
If you have a question let me know.
