Although a failing alternator can increase whine, it's usually a tired battery that's the problem.
An alternator puts out a high frequency pulsating DC voltage that's filtered by the battery.
If you are using ANR headsets with sensitive electronics, this problem can be exacerbated.
Filtering the alternator B lead will not help, but making sure your engine is well grounded close to the battery negative terminal and system grounds will help.
Vern
