As luck would have it my alternator failed 500nm from home! I guess it’s karma. I bought a velocity as a 4 seat addition to my RV4. Original builder equipped the plane with an automotive alternator with an external regulator. I also discovered that my tachometer is electrically driven by an “AC” output on the alternator itself. As I understand, it’s a lug that connects directly to the stator to prove AC electrical impulses to tachometer.
Does anyone know of a compact alternator that has an AC or Stator lug??? At this point I don’t care if it’s externally or internally regulated. Internally regulated is ideal but at this point I’m desperate! Thank you!!
Pics show the destroyed cooling fan installed then removed.
