NovaBandit
I seem to have a bit of alternator whine from my PlanePower 60 amp alternator in my headsets. It is occurring whether or not the intercom or radios are active (I can hear it when nothing is breaking squelch). The whine goes away when I switch the alternator off.
Also, I have a PlanePower 30 amp vacuum pad mounted secondary alternator. When I switch to this alternator, at the same RPM, putting out the same amperage, I get NO whine. Both alternators have their own shunts and ANLs, but then are joined together after the shunts before connecting to the main power bus (before the firewall passthru even). The field wires for both alternators are fairly well separated from all other wiring.
My gut feeling is that the PlanePower 60 is just a noisy alternator, and I'm tempted to replace it with an externally regulated alternator at some time down the road. In the meantime, are there any tricks to reduce this noise?
