What other fixed pitch props are available for an RV-6A with an 0-360. I have the big sensenich cruise prop that may have a problem.
Sean,I'm also looking to replace a Sensenich on a RV-6. I'm tilting towards the Whirlwind. What did those who went in this direction do to compensate for the loss of weight with the new prop? I have an O-320 and the weight and balance tends towards tail heavy already.
Thanks!
Cheers, Sean
Thanks!
Cheers, Sean
Thanks James/Butch! I did some guesstimation and found that the CofG does appear to be within limits with the Whirlwind (-22 lbs.) with due attention to max luggage and reduced fuel.
Cheers, Sean
