gyoung
I'm starting to work on these tanks for the partially completed kit I picked up 15 years ago. It appears the original builder had a different idea for the fuel pickup and reversed the original pickup fitting, possibly for a return. I've already modified the left tank for a flop tube so I'm only concerned with the right. I do need a return in the right for my AFP purge valve so I'm tempted to leave it as is. I don't see any inherent problems with this pickup but I might move the return lower and switch to a -4 fitting to match the return hose. Any comments?
For the sharp-eyed among you, that IS the left sender plate in the right tank. Discovered after the photo.
![right fuel tank.jpg](/proxy.php?image=http%3A%2F%2Fwww.bentwing.com%2Frv-6%2Fright+fuel+tank.jpg&hash=f1ea8a109ef27d2339d2dc55f3bf3c26)
