Why not?
Hey Dave:
I think your idea has merit. Your best plan would be to allow for several changes to the outlet size while installing your 1st version. I used about 1.2:1 outlet to inlet ratio. This ratio is not 'outlet flow optimized', of course.
Caveat: keep in mind that the exhaust air is very warm (150F+), and the side of your airplane is made from aluminum, which conducts heat very efficiently. This translates into a large dose of cockpit heat on a continual basis. Very comfortable at higher altitudes and colder ambient temps; not so much in Texas in July. Early flight testing on my version led to the Dynon going grey scale, which I think it does at 140F? So, if the panel was 140F, what temp do you think the cockpit was? 'Time to land and re-think this mess' is about how I would describe it.
On the upside, you can experience what it's like to fly a WW2 fighter, as these ships had similar heating characteristics. So, I've got that going for me...
Summary: Since I am well along with this experiment, I will follow thru with changing the engine exhaust to exit out the bottom so I can get equal flow from the right and left cooling outlets (the current exhaust exits out thru the rt exit, above the wing, which confuses the flow on that side), but I still doubt if the interior heating issue can be solved without rebuilding the fuselage from composite, or installing some kind of shielding on the outside of the fuselage. I doubt I will carry the experiment that far, and will likely end up with a bottom outlet for both exhaust and cooling: it's easier to insulate the lower skin to reduce cockpit heating.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
You can see the outlets are actually easily changeable panels, and the rt outlet has the exh tailpipe in a less than optimal place. I will build up a new exh system to move the outlet to the bottom, seal it as well as possible, and then proceed with tweaking the bluff body outlets. It is possible that by balancing the two outlets, the cockpit heat will subside?
We shall see!
Cowl flaps: didn't work either, again due to the exh pipe changing the rt side flap size (about 60% of the left side), which allowed the rt side to be an INLET when the cowl flaps were deployed.
20/20 hindsight!
Carry on!
Mark
