n468ac
Maybe someone here will have an idea...
We've been flying for a year with our D10 without any issues!
This week we installed the EDC (purchased with the D10 many years ago, but not installed) with the OT we got directly from Dynon a couple of weeks ago. After the installation we booted up the D10 and added OAT to the left side of the screen. It worked! but the OT was 86C
... I then flashed the Dynon D10 to the current version 1.13.00 (note we were already at 1.13.00 before this flash) as i read and was told by Dynon, the EDC and D10 needed to be at the same firmware. Now after the reboot ... no OT!! I flashed the D10 another three times and still can't get the OT to show up. Between every flash i removed power from the Dynon D10 and the keepalive. Then restored power and waited until the ALT tape showed up.
I used the update support program to get the data below.
D10 at version 1.13.00
EDC at version 0.00
UPDATE: tested the EDC with a magnet today ... the heading changes
So it looks like the EDC is working ... but still no OAT
Here is the datamap download...
BUMP
Update: EFIS-D10 v1.13.00(Serial #1295)
EDC-D10 v00
Tried flashing the unit again tonight ... still got the above version numbers.
Tried MagCal with the EDC ... worked great ... the MagTape is working off the EDC as tested by using a magent.
Still no OAT
EDC at version 0.00
Code:
Chip ID Name Version Start Length Crc Hex CRC
1 19 PSoC 1 Loader 1 237 19 25669 6445
1 1 PSoC 1 Code 27 0 235 50951 C707
1 5 PSoC 1 Cal Table 0 235 1 552 0228
1 12 Ex Version Num 1 13 0 0 0000
1 15 PSoC1 Config 17852 0 0 0 0000
1 17 Serial Num 256 1295 0 0 0000
2 20 PSoC 2 Loader 1 244 12 64898 FD82
2 2 PSoC 2 Code 10 0 230 2581 0A15
2 6 PSoC 2 Cal Table 1 230 13 35732 8B94
3 21 PSoC 3 Loader 5 239 17 5154 1422
3 3 PSoC 3 Code 13 0 129 5594 15DA
3 7 PSoC 3 Cal Table 0 234 4 23099 5A3B
3 8 User Cal Table 0 129 1 9857 2681
3 9 EEPROM 37 230 4 8977 2311
3 10 Checklists 0 130 100 47540 B9B4
4 22 PSoC 4 Loader 1 244 12 21413 53A5
4 4 PSoC 4 Code 7 0 243 57087 DEFF
4 13 Airspeed Config1 24036 20600 11446 6759 1A67
4 14 Airspeed Config2 6290 10 0 0 0000
5 11 EDC Code 0 0 110 45193 B089
5 16 EDC Cal Table 0 111 4 17476 4444
5 18 EDC User Cal 0 110 1 17476 4444
5 23 EDC Loader 2 116 12 25386 632A
BUMP
EDC-D10 v00
Still no OAT
