I am mounting a GRT ADAHRS this week and plan to mount it to one of the two support ribs that runs from the Firewall to the bulkhead behind the panel. I am wondering if anyone knows whether or not this is designed to run parallel to the airframe's longitudinal axis. I realize that these were not pre-drilled and may not exactly match the drawings.
The pitch and roll can easily be set via configuration, but the yaw axis must be measured and the offset manually entered. While I plan to measure, it won't be easy and knowing the likely orientation will help.'
Larry
Larry
