Not sure if this would be the place to post since it may be a TruTrak issue but since their forum is inactive I'll try here since it is an Rv10 in progress. In the process of wiring AFS efis, ViZion AP in my 10 at ap turn on the servo goes immediately to about stick forward 1 inch approx or nose down. Since I've never had a vertical axis ap, how do I align the linkage or adjust servo so at turn on the servo doesn't jump to nose down immediately? I believe there was a step when installing servo to align triangle so the vertical portion was at zero degrees? So I'm not sure if I need to adjust elevator/servo linkage or should there be a "zeroing" adjustment on ap?
Dave Ford
Cadillac , Mi
Dave Ford
Cadillac , Mi
