I know - I have heard all about the issues with this unit and am regretting installing it in the first place - but I have it now!
I have moved the aircraft to South Africa and as a result, it needs reprogramming with new data before I can get the correct HEX code to register it. The manual seemed to suggest that by connecting to your laptop, the necessary software would pop up (ie, built into the unit). The local avionics shop says "not so" and that the required software costs $850
- that's if you could talk to AmeriKing which you can't because the FAA have closed them down........ ![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So, any ideas? Anyone got a copy of the necessary software that I could lay my hands on?
