N309MK received her airworthiness certificate this morning and flew early this afternoon! Woo Hoo!!!
Conducted fast taxi in accordance with my test plan at 15,20 and 30 mph and survived![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
First flight took off and immediately had high CHTs, especially on #2. Went as high as 465 on #2 for 30 second and 420-30 on others. This engine was broken in on my BD4 for 70 hours and all CHTs ran in the low 300's. Its an Xp-360 with one slick and a P-mag. I pulled power to idle asked the tower for an immediate landing and did my first wheelie in an -8. What a nice machine!!!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I had the pmag in program A which I believe is the most aggressive so I shut down and switched to program B. I removed the cowling and checked baffling. Its all very tight. Oil temps never got above 170 - I have the oil cooler located low on the left engine mount fed by a 3" SCAT and a glass duct on the outlet.
I put it all back together, let things cool a bit and tried it again. Temps were lower but #2 still went up to 450 in the climb. I leveled off at 2000 throttled back to 1700 and stabilized at 100mph. All other CHTs eventually dropped to 310-320s while #2 stayed at 410 for about 10 minutes and then finally dropped to about 350-360. OT was 164 and pressure at 70. All EGTs were within 50deg of each other from between 1150-1250. It really surprised me how long it took for #2 to cool compared to the others. Level at 2000 ft I advanced throttle to 24" and 2600 RPM and stablized at 189MPH all CHTs rose with 1,3 and 4 going to about 380 and #2 going to about 410.
Once on the ground and the engine off all CHTs drop and equalize quickly within 3-4 degrees of each other.
One thing I didnt do was glass then ends of the inlet ramps as I figured they are between the baffling so who cares..am I wrong here?
Any ideas on why #2 would be so much higher? The Oil cooler inlet is at the rear baffle at #4. I have the stock VANs baffle kit with the tall **** in front of #2. Have any of you guys cut this down and did it help? I can block off some of the oil cooler inlet to strike a balance between oil temp and CHT..
Anyway...despite the high CHTs I have the RV grin (photos and video soon)!!!
Thanks for all the advice, help and healthy debate along the way!!!
Ken
Ken
