The 912s series will run fine with 100LL. Rotax recommends 25 hr oil changes if you use 100% 100LL. Adhere to their schedule.
Having said that, the engine is happier if you use mogas. The difference in the oil and oil filters is amazing - lots of lead accumulating when running on 100LL, nice and clear on mogas. The gearbox will require less frequent rebuilds if you use mogas.
Major downsides to mogas are ethanol and its associated problems, fuel stability and vapor lock. I fly a high wing with the 912S and am not as concerned with vapor lock, although it is a concern.
In reality, I find that I most often have some kind of mogas/100LL mix in the airplane. If I'm flying frequently, I'll use 100% mogas, but if I know the plane is going to sit for a while, I'll fill it with 100LL. By blending, it also keeps the ethanol content below 5% (and let's not get started on the Ethanol debate...)
TODR
