randyintejas
I have been gathering information off this site and individual build logs for about 4 months and the wealth of knowledge I have received from this resource has been invaluable. When trying to get started on a project like this I have found that those who took the time to list the tools and shop information to be a huge help! So I’m doing the same. I added on to my house about 8 years ago and build a separate garage so I would have some place to store building materials and so it could also be used a real garage latter. Thankfully I built a 2 car 28 X 35ft garage and had planned at some point to build a shop in the rear section. Little did I know that it would become an airplane factory! Because it was for storage I did not finish it out so… the work began. I first ran a 20amp 110 (for compressor) and a 30amp 220 (Heat/Air). I had already wired for 10amp 110 for light and a separate 15amp for plugs. Next I had to seal up the garage doors inside and out. I put sheet foam inside the panels and then covered the doors in sanded plywood (doors face west in Texas SUN!). I had a lot of ½ inch green sheet rock left over from the house so it got used on the walls (bulkheads). After the walls were finished I needed storage for all the garage junk and plane parts so I decked the ceiling in ¾ OBS. I installed several 15amp plugs for tools and put in 10 4th T8 florescent lights.
Tools purchased:
Sears: Craftsman 12 inch Drill Press, 10 inch Band Saw, Belt Sander, Torque wrench, Screwdrivers, Box Wrenches, Rulers, Grinder Stand, 3 Drawer Tool Box addition, Socket Wrenches and Sockets ( a lot of my tools were really old and in bad shape)
Home Depot: Grinder, Oiled Compressor 30 Gallon 110 20amp, shop Vac, Tape Measure and all building supplies
Harbor Fright: Air Die Grinder, Air Angle Drill, Tap and Die Set, Tons of Clamps, Vice, Air Hose, Calipers and a cheap bench Metal Break.
Isham Tool Kit. I cannot say enough about this kit! Very impressive! Just buy it and don’t think about it anymore.
I spent about 3 months gathering tools and finishing out the new Airplane Factory! I have seen other post that mentions you will need to spend around $6,500 on tools and I have found that to be a very true statement. I have tried to gather everything I need upfront (I know I will need more) and have found that to be an accurate cost guide.
Compressor plumbing: Because my Garage is 35ft long I decided to run copper pipe from the compressor at the back and up to the hose reel at the front. I also put in a connection at the tools bench and another half way down the bay and under the reel (close to the floor) I put in a ball valve so I can drain/bleed off the line/reel. I used an 8ft rubber hose (with quick connect) to connect my compressor to the manifold/plumbing system. I also installed a Miltion air separator and a Kobalt regulator. Most of my air fittings I purchased at Lowes.
I will try to include some pic’s for those who are interested and I would like to give my sincere THANKS to all who have contributed to this fourm.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Tools purchased:
![r9ip0p.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi39.tinypic.com%2Fr9ip0p.jpg&hash=06244cfaeb6db9f25c1ba5642ff59b54)
![dvdld.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi43.tinypic.com%2Fdvdld.jpg&hash=5ab6dcf130b990ed15b90758193295e8)
![212g96g.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi41.tinypic.com%2F212g96g.jpg&hash=1a0fbc5351ecb1e4daeed10200df2e22)
![rm06ch.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi43.tinypic.com%2Frm06ch.jpg&hash=7c87a991e6a922dcb85b9023db939177)
![2a634uc.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi42.tinypic.com%2F2a634uc.jpg&hash=c7f09879930116023eb343daa55870aa)
![1rzoe0.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi42.tinypic.com%2F1rzoe0.jpg&hash=0611a737cfae05c0b2cb3ad651a24a01)
