Did anyone build in return air from the interior cabin with there A/C install, or are you just pulling air from the tail? Just curious how people have handled this.
Lynn
Do you have the standard or larger evaporator? If you have the larger one, I've been working with Bill on a solution. Currently it's two transition pieces that cut through the upper Bulkhead piece and go straight into the unit.
If it's the standard I would call Bill and see what he suggests. You defiantly want it to come from the cabin vs the tail.
Here are a few pictures showing the transition pieces, how they come through the bulkhead. Also a picture of how it's wired in the tail cone and how the cap piece will fit. Bill is working on that part which will have recessed edges to match the transition piece as well as a grill for the airflow.
